Loose Steerung Column, H E L P ! ! ! !
I am hoping someone can help me with a small steering/tllt wheel problem. I have a 93' coupe and the steering wheel at the tilt joint moves a little. I took the wheel off and tore it down all the way down to the bearing and race and the problem doen't seem to be associated with the this shaft. If you grab the wheel and push toward the 7 o'clock position it'll wiggle a little (there is resistance up against the tilt spring). After buttoning up the wheel I moved under the column and took a look to see if there was anything loose (removed the brace to get a better look) and things look fine, although you really cant do much with this adjustment except when you are replacing the column. I'm STUMPED ! I've changed columns before and replaced steering wheels before but I have no clue on where the problem is... any ideas would be helpful.
p.s. I just recently purchased the car and this problem was probably caused by the old owner hanging onto the wheel getting in/out of the car, thought the info might help
Thanks
Thanks
