Need help again
Old Oct 10, 2006 | 08:15 PM
tasteum's Avatar
Default Need help again
Hello folks,
i have an 86 vette i installed 58mm throttlebody / adjustable fuel pressure reg / 24lbs injectors / custom burnt chip and it wont idle, it kinda pops at the plenum / i adjusted the TPS @ a .54 / new IAC valve, oh in addition i installed a new cat and free flow exhaust system, please help it may be a vacuum issue??? Im really not sure so im looking for some help, abd does anyone have a link or a copy of the vaccum line assembly on this vette???
Old Oct 11, 2006 | 12:47 AM
Default RE: Need help again
Have you used a piece of heater hose about 3 feet long to listen around the intake for a vacuum leak? You can also use carb spray to spray around and see if it picks up idle. I had a lean problem with mine when I first built it, come to find out, some injector dork sold me some 19 lb injectors for a 305 TPI instead of the 22 lb for the 350. That fixed all my problems. Have you got timing set right? Did you unplug the set timing connector by the master cylinder before setting timing?
Old Oct 11, 2006 | 06:24 PM
tasteum's Avatar
Yes timing was set at 6 degree and did disconnect the connector, pretty sure the problem is that the vacuum lines are not right, due to the EGR valve on the intake is not closing, i removed it and it works when i put a vacuum / pressure tester on it. does anyone have the the diagram they could send me on the vacuum system???
Old Oct 12, 2006 | 07:42 PM
Superdzzz's Avatar
Give this a shot:
http://www.chevythunder.com/fuel%20i...um%20lines.htm
Should be what you need[8D]
Old Oct 12, 2006 | 08:53 PM
I'm just watchin, listenin', and learnin'!
percentages
Nov 23, 2006 11:26 AM
TommyC19
Sep 7, 2006 03:00 AM
Scatman
Jul 12, 2006 07:04 PM
Lee Willis
Jun 21, 2006 09:40 PM
SonicEdge
May 3, 2006 07:37 PM
