obd11 code 1416
Old Dec 15, 2006 | 07:30 PM
tg's Avatar
tg
Default obd11 code 1416
what does it mean other than secondary air induction. how doy u fix
Old Dec 15, 2006 | 08:26 PM
Default RE: obd11 code 1416
Secondary air induction refers to your air injection system into the exhaust stream for emission control. More than likely your air pump or relay for the pump is bad or a check valve also. Difficult to diagnose here with out scan tool. [8D]
Old Dec 15, 2006 | 11:06 PM
gorichb's Avatar
I have had this happen both on my truck, and my Vette. It's most likely the check valve. What year is your Vette?
When it first happened with my truck I took the check valve off, and cleaned it, that worked for about 3 months than it set the code again.
Just change the check valve, it's fairly simple to do.
It can be your air pump. Listen to see if you hear the air pump come on at start up, or have someone start the car while you are touching the air pump, you should feel it come on for a little while, and shut down.
Good luck
mdsbch
Oct 12, 2006 01:20 PM
kggoodier
Jun 13, 2006 01:34 AM
94corvette
Dec 4, 2005 01:38 AM
Lee Willis
Nov 30, 2005 01:40 PM
jsteezy1290
Jul 28, 2005 12:28 AM
