SLOW Blinkers
Old Jun 10, 2007 | 06:55 PM
m.martince's Avatar
Default SLOW Blinkers
[]One day I pulled off realfast and instead of my tires spinning, those puppies gripped and I took off! I heard a weird squeal sound and my Service Engine Lamp came on. I pulled over and shut er down. after walking around a checking to see if their were any damage, I restarted my 86 C4 and headed home. My blinkers did'nt want to work at all. After about 10 minutes they started to work very slowly. The next day they were still operating slowly. I replaced the blinker relay behind thedash and they work better, but still seems alittle sluggish. Also I re-converted my system to R-134a. The prior owner did'nt do it properly. They left all the seals original. Corvettes run at a high pressure because of the high performance eingine. I was thinking about removing the smog pump. Its makes a slight funny noise every once in a while.[X(]
Old Jun 10, 2007 | 07:15 PM
Default RE: SLOW Blinkers
ORIGINAL: m.martince
What made you think the flasher relay was faulty? Hopin' for a little 'plug n pray', huh? [sm=pcwhack.gif]
So they work better, but still a little sluggish?[sm=smiley25.gif]That means that the new flasher is better, but still in need of improvement. Take it back, and get another. If another works one works better, but still with sluggish flashers, then we can start drawin' conclusions (the originalrelay was good).
Keep us posted here...
Old Jun 10, 2007 | 07:36 PM
78buckshot's Avatar
I think I'd start checking the alternator for slipping belt and rough bearings, the squealing may have been the belt not keeping up with the high RPM and now possibly the alternator isn't putting out the proper voltage.
Old Jun 13, 2007 | 11:59 AM
m.martince's Avatar
The alternator is only about 1 month old.[X(]
Old Jun 13, 2007 | 02:21 PM
The blinkers on my '87 were slow and shortly after they became slow The car would not start after warming up. After investigateing I found the ground terminal on the stupid side mount battery had become slightly loose and carroded in side the threads. After cleaning it with baking soda and toothpaste and retightening it there is no problem to date and the blinkers work fine.
lakesidebob502
Feb 1, 2008 08:03 AM
bobalou
Jun 13, 2007 12:26 PM
3BlkC4Ragtop
Nov 11, 2006 09:32 AM
JOHNBOSCO
Apr 20, 2006 07:40 PM
LDarcey
Nov 8, 2005 01:34 AM
