transmission shifting hard
Old Aug 14, 2007 | 06:35 PM
buddym3's Avatar
Default transmission shifting hard
i have a 98 corvette with 44000 miles bought it from a private owner so no warrinty i have only had it 2 months it seems to shift a little hard when you first start driving then as it warms up it gets a little better any ideas ? it is an automatic
Old Aug 25, 2007 | 08:43 AM
Default RE: transmission shifting hard
ORIGINAL: buddym3
Two things I can think of (probably both wrong, but keep 'em in mind anyway)...
If power to the TPS has been disconnected with the battery still CONNECTED, the computer changes the default shift cycle in the tranny to default mode, until after severaldrive/shift cycles. No harm will be done if this is the case.
Scenario two might indicate a problem - electrical, or mechanical, or both. The fluid pressure and/or TC lockup modes have changed. At 44k, I'm guessin' there's an electrical problem. The computer might or might not be able to tell ya where the problem is. To confirm an electrical problem: Next time you get the hard shift, pull over, disconnect the battery for a few minutes, reconnect and go. If you get a few good shift cycles, you probably have a short circuit somewhere, with no mechanical problems.
If 'two' isthe case - an electrical problem, continued tranny operation in this mode WILL lead to mechanical problems...
Old Aug 26, 2007 | 08:16 PM
9340Vette's Avatar
How does your fluid look? For all you know the prior owner maybe added something to the fluid and it takes heating up for it to thin. Just a suggestion.
gjfrye
Aug 15, 2008 10:57 PM
corvettec5
Aug 15, 2008 07:13 AM
C5Y2K
Jan 24, 2008 04:50 PM
buddym3
Aug 12, 2007 03:39 PM
stevesrubyred93
Feb 28, 2007 10:04 PM
