Problem with Headlights C3 '77
Old Jun 8, 2011 | 05:02 AM
xchief227's Avatar
Default Problem with Headlights C3 '77
Just took ownership checking over the car and found when headlights are on right turn signal indicator on dash stays on loose right front turn signal light and loose right blinker. Can this possibly be a grounding problem or possibly turn signal switch ? PleeZZZZZZZ HELLLLLLLP !
Old Jun 22, 2011 | 01:03 AM
Default I'll take a guess!
Take a wire and attach one end to a good ground and touch the other end to the outside of the right bulb socket. If everything works OK with the jumper hooked up then you have a bad ground.
If no change then post back and we'll try the next step.
Regards,
PG.
Old Jun 22, 2011 | 08:38 AM
xchief227's Avatar
Thanks I will try that I felt it is a grounding problem. I will get back if not!!
Thanks for your recommendation
Wrangler47
Jun 24, 2006 08:08 PM
t1vette
Apr 26, 2006 12:38 AM
HRS84VETTE
Feb 12, 2006 10:40 AM
99hdtop
Oct 19, 2005 10:08 PM
wterwal
Sep 7, 2005 11:21 PM
