1965 Air Filter Adapter
Good afternoon,
I just purchased a 65 convertible with a 327 cu in 300hp. It presently has a Holly carburetor with a 5 1/8" opening. I would like to keep the engine stock looking as much as possible by using the orginial 2 horn air filter (that I have) instead of the chrome Holly filter that is presently on the motor. The original corvette air filter will only accomadated a carburetor that has a 4" opening. Is anyone aware of an adapter that will go from 5 1/8" (carb. inlet) to the 4" filter housing?
Thank you for any help or suggestions.
PLEASE NOTE: I have found adapters that will go from 4" to 5 1/8" but because the way they are constructed they can't be turned upside down.
Thank you 73shark for your forum welcome and your valued input. Due to my present schedule I haven't had a chance to take a good look at what it will take to make this modification (with drop down) and I certenly not want to trash a perfectly good 65 air filter if it was not going to work. If any one else has a suggestion on how this modification can be made, I'm open for suggestions.
Thank you
Thank you
Happy Holidays Everyone,
It has been some time since I posted a "HELP" request regarding modifing a double snorkel 65 air filter to fit a Holly 3520 (with elect. choke). As such, I was circling back to see if anyone has accomplished this modification or knows of anyone that has.
Thank you in advance.
Thank you 74Harley for your input. I presently have a Performance Manifold on the car with a Holly Carburetor. To go to a Carter AFB, etc. will require me to obtain a manifold and carburetor at considerable expense. As such I was hoping someone might of already tackled (invented the wheel) on this modification and could share it.
Thank you again 74Harley
