Powerglide
Hello folks, got an issue with powerglide transmission in 67 with 327 all stock when the car is warm / hot at a stop light it will go into false neutral give it just a little gas and it goes back into gear, I have adjusted the band 3 times 72 inch lbs then back off 3 full turns. It will do ok then go back to same as it was. Anybody have any ideas?? I have been looking a a Sonnax servo kit to add more pressure to the band that holds the drum?? Thanks for any info on this.
