Wierd noise after shut down
Old Oct 14, 2019 | 04:35 PM
Santoli14's Avatar
Default Wierd noise after shut down
Hey Forum folks...
In my 67, when I shut the car off, I get pre-ignition shudder for about 5 seconds and then a whooshing noise like a release of either air or liquid...could be many things evidently... anybody out there experience this and what it turned out to be?
Old Oct 15, 2019 | 02:05 AM
Tom O'Connor's Avatar
I drag the clutch when turning key off. This stops run on.
Old Oct 15, 2019 | 10:03 AM
The run on resulted in the engine running backwards instead of sucking it was blowing. clutch kill it.
Old Oct 15, 2019 | 12:06 PM
Santoli14's Avatar
Default Weird noise
Guys... understand that the clutch kill will stop it...but what are the likely reasons it's happening so that I can fix it? Thanks, Rob
Old Oct 16, 2019 | 10:40 AM
If the carburetor has an idle stop solenoid then it may be sticking and not allow the throttle plates to completely close on shut off. Another cause could be running a spark plug that's a grade or two too hot and you're getting preignition from that. Also the engine may be running too hot.
Old Oct 27, 2019 | 01:35 PM
Santoli14's Avatar
Default Run on
Thanks Shark...need to check the carb and plugs...
jgoose
Nov 6, 2011 09:54 PM
kosio
Nov 8, 2008 01:52 AM
delaughter68
Nov 19, 2007 07:34 PM
renegade664
Aug 5, 2007 09:03 PM
kemboz06
Corvette C5 Z06
May 2, 2007 01:56 AM
