1973 ride height
Old Feb 19, 2012 | 09:02 PM
  #21
That's what I thought and I have a folder called "Corvette C3 Forum". That doesn't seem to work. And when I checked over in the Chevrolet forum, I've got several folders listed but only get the Tahoe stuff and don't even have the full name. Should be Tahoe and Suburban.
I see that the front spring bracket are part of the lower A-arm cross shaft.
Old Feb 20, 2012 | 09:40 AM
  #22
I was hopin' that I found the solution to the issue of subscribing to individual forums.
Can't do a thing about it from my end.
Note to, that the front right strut is labled "Left".
The spring mounts in the same location, in the verticle line between the upper and lower "A" arms, as the coils would.
I really believe this to be a great setup overall. No complaints here. ; )
Old Feb 20, 2012 | 08:22 PM
  #23
Couldn't see the right strut in the pics.
I'm sure it's a good way to go. GM must also since the last two iterations used a similar setup.
Old Feb 20, 2012 | 08:42 PM
  #24
If you look along the top edge of the lower "A" frame you can see it.
rick56
Dec 22, 2008 02:29 PM
jgall
Sep 25, 2007 10:41 AM
jmholtzclaw
Jul 5, 2007 09:42 AM
thebrains
Apr 3, 2007 12:32 AM
red90vettesc
Feb 26, 2007 09:37 AM
