69 Drive Axel U-Joint?
Old Jun 24, 2007 | 11:17 AM
alive69's Avatar
Default 69 Drive Axel U-Joint?
Have a u-joint throwing a little rust debris from 1 cup. Probablydue to no grease left in there. Maybe someone out there has had this issue.It's the joint by the wheel not the differential. Havethe carblocked up and it looks like it should slip right out of there. Can it be that easy?? Can I pull that joint without tearing a lot of stuff apart under there? Need some advice. Thanks, j
Old Jun 24, 2007 | 01:05 PM
pg's Avatar
Default RE: 69 Drive Axel U-Joint?
Hi alive69, you will have to lososen the camber bolts to rotate the cam so you get enough clearance to get the half shaft. Just mark the bolts first and line them up again. Hope that helps, PG
Old Jun 24, 2007 | 04:21 PM
ORIGINAL: alive69
??? [sm=wtf.gif][sm=WTFsgign.gif]
Is the little rubber seal still there between the lip of the cup and the neck of the x-piece?
Old Jun 24, 2007 | 04:45 PM
alive69's Avatar
Yes, cwb. It is intact. I actually used a screwdriver and lifted it abit to see if I could determine if the joint wasdry. Could not see enough to determine so guessed that cup was the problem. j
Old Jun 24, 2007 | 04:51 PM
78buckshot's Avatar
If you can see rust from the bearing cap the U- joint is allready trashed, as long as you have the shaft out you should think about replacing both joints. Also when you remove the shaft, check the end play in the differential yoke, about 1/16 of an inch is OK.
Old Jun 24, 2007 | 09:58 PM
ORIGINAL: 78buckshot
Sorry 69; I didn't know you had the half-shaft already out.
Yes, like buck said, replace both U's with heavy-duty, SERVICEABLE (with grease fittin's) x-pieces.
BE SURE THE CAPS ARE INSIDE THE LITTLE NOTCH OF THE YOKES, WHEN RE-INSTALLIN'...
Old Jun 24, 2007 | 10:06 PM
IMO, change the ones in the other shaft too, then ya can forget about 'em.
All new, is better than half new.
Old Jun 24, 2007 | 11:09 PM
I agree with getting joints with zerks. Make sure that the joints are installed such that the hole for the zerk is in compression when axle is going forward.
Old Jun 25, 2007 | 01:26 PM
wrwalke's Avatar
And at like $12-20 each. Definitely worth putting in all new stuff while you have it up in the air and ripped apart.
bill.
Old Jul 18, 2007 | 01:19 PM
alive69's Avatar
They arereplaced and reinstalled. Turning the camber boltslets the1/2 shaftfall right out. Removing the nuts from the u-bolts,on the differential end, is a slow process butwith patience theycome off.Cleaning the u-bolts and new nuts and lock washers puts itback together quickly. Thanks for the help here. j
bp2826
Aug 5, 2013 08:10 PM
Dzbo
Apr 5, 2013 09:41 PM
gizwilly
Mar 27, 2007 08:56 AM
Black86vette
Nov 12, 2006 09:42 PM
damon2020
Jul 5, 2006 09:54 PM
