alarm
Old Apr 22, 2008 | 05:29 PM
orangevette's Avatar
Default alarm
Okay, here I go with another problem. My alarm does not work. I turn the switch, by the left front fender, to the on position, butthe alarm stilldoesn't work. Is there another switch besides the key switch?
Also being a new member, signed on April 20, I think this is a great forum. I've been reading most of the answers to the various problems and like what I read. I happy to be a member.
Keep it up.
Old Apr 22, 2008 | 10:34 PM
Default RE: alarm
Not sure if yours ('77) is the same as mine ('73) or not but mine has a relay which I think is located in the jack compartment that is operated by the key switch which in turn applies voltage to the alarm horn. Yours might be different tho. Maybe someone else here can help.
Old Apr 22, 2008 | 10:43 PM
pg's Avatar
Default RE: alarm
Hi orangevette, my alarm didn't work either so I just use the fender switch as a kill switch. PG.
Old Apr 23, 2008 | 05:30 AM
watwheel's Avatar
Default RE: alarm
Welcome orangevette!! Try tracking the power by testing for voltage at the key switch. If you are good there, check for voltage at the horn with the key in the on postion. At least you should be able to pinpoint the problem. Good luck.
Old Apr 24, 2008 | 09:23 AM
Default RE: alarm
Hey, 73shark, pg and watwheel, thanks for the replies. I did forget to mention that my vette is a 74. I will trace the power to the switch and the horn. Thanks again.
watwheel
Dec 26, 2006 11:24 PM
hombredog
May 23, 2006 02:10 AM
Superdzzz
May 6, 2006 12:39 PM
doc1
Aug 9, 2005 01:16 AM
Roadhack
Jun 10, 2005 03:11 PM
