Bolt Questions
Old Dec 19, 2010 | 01:29 PM
SCHOON's Avatar
Default Bolt Questions
Two questions:
What length header bolts are required for a 74, with SB 350
Are 12 point heades better that the standard heads.
Thanks,
Schoon
Old Dec 19, 2010 | 02:42 PM
Use 6 pt bolt heads and 6 pt sockets. There is more surface to surface.
Less chance of socket slipping off and bustin' a knuckle.
Old Dec 19, 2010 | 10:02 PM
partsman41's Avatar
Bolt length is indicated by the thickness of the flange. Several manufacturers (Moroso, Arp?) are making locking header bolts,there is some kind of an insert that locks the bolt in once tightened,advertised to end the repeated retightening of header bolts. If your primaries are over 1 5/8 on some headers it is very difficult to get a wrench on a hex head bolt making the 12 pointers a little easier to work with.
Ron
Old Dec 24, 2010 | 04:54 PM
There's also a reduced size hex head header bolt that has a flange that's slightly bigger than the bolt diameter.
I've used socket head bolts for those really tough ones.
MERRY CHRISTMAS to all.
1974corvetteowner
Dec 4, 2007 02:18 PM
dar322
Dec 3, 2007 08:52 PM
Wedge
May 15, 2007 07:39 AM
Wedge
Dec 3, 2005 07:44 PM
68Stingray
Oct 27, 2005 01:10 AM
