headlights
Old Oct 15, 2008 | 09:24 AM
budman30562's Avatar
Default headlights
Hey guys have a 1977 c3 every time i start car headlights pop up but will not go down until i shut car off and then i have to manually push them down all hoses r correct could there be some type of vapor lock or something thanks
Old Oct 15, 2008 | 01:35 PM
pg's Avatar
Default RE: headlights
A bad Check Valve might be the problem. PG
[IMG]local://upfiles/2883/0D67966AA4DA45AB834FE93D8F60BCDE.jpg[/IMG]
Old Oct 15, 2008 | 03:47 PM
also when i turn headlights on before i start car only one side comes up this has me baffled
when i block vacuum on either relay light will not come up how could it be just one relay thanks a bunch
Old Oct 15, 2008 | 04:46 PM
SCHOON's Avatar
Were you messing with vacuum hoses before the problem started?
If the answer is yes you need to follow PG's diagram he posted for you.
Schoon
Old Oct 15, 2008 | 09:19 PM
Welcome to the Corvette Forum. Did you check the manual pull valve below the steering column. I'm assuming that the 77s still had one.
Old Oct 16, 2008 | 12:39 AM
pg's Avatar
ORIGINAL: budman30562
There is only a limited supply of vacuum in the tank with the engine off, you no doubt exaust that vacuum, because the other side has a small leak it will not go up.
Do both sides go up with the motor on?
PG.
Wrangler47
Jun 24, 2006 08:08 PM
t1vette
Apr 26, 2006 12:38 AM
HRS84VETTE
Feb 12, 2006 10:40 AM
99hdtop
Oct 19, 2005 10:08 PM
wterwal
Sep 7, 2005 11:21 PM
