power steering filler
Old Mar 5, 2008 | 03:21 PM
Marty73's Avatar
Default power steering filler
I know this question shows how unmechanical I am but I can't find the power steering filler in my 73 small block. Where in the name of heaven is it? It would seem it would be right up front or somewhere near the oil filler.
Marty73[:-]
Old Mar 5, 2008 | 03:42 PM
78buckshot's Avatar
Default RE: power steering filler
Hi Marty73, power steering reservoir is part of the power steering pump. You'll find the pump on the driver's side, front of engine, very low under the alternator. It will have a short belt driving it. The reservoir cap is about two inches in diameter, black, twist 1/4 - 1/2 turn counter-clockwise to remove. Don't over-fill, it won't take much, you can use automatic trans fluid if you don't have power steering fluid.
Old Mar 5, 2008 | 05:23 PM
Marty73's Avatar
Thanks 78 buckshot, no wonder I couldn't find it.
Old Mar 5, 2008 | 07:04 PM
78buckshot's Avatar
It's normally dark and greasy in that area and difficult to see and also hard to fill, use a small funnel with hose attached. Glad to help.
Old Mar 5, 2008 | 09:02 PM
Texas Jim's Avatar
Don't forget, check to line on the stick attached to the cap, and check when fluid is hot, no?
Old Mar 5, 2008 | 09:12 PM
Best hot but I think most of them had a hot line and a cold line to check to on the dipstick.
Dogcow750
Aug 28, 2007 11:23 PM
lil red corvette
Jul 10, 2006 09:59 PM
jetmech09
Jun 8, 2006 09:49 AM
imb1987
Feb 8, 2006 12:38 PM
gs821
Jan 12, 2006 12:27 PM
