1986 headlight problem
Old Feb 16, 2008 | 08:11 PM
my86vette's Avatar
Default 1986 headlight problem
My 1986 right side headlight motor does not retract without assistance. I have replaced the main gear (which had a bad spot on it), but it still will not retract on it's own. It opens and turns on fine.
I hope someone can give me some advice!
Old Feb 16, 2008 | 09:18 PM
YANKEECORVETTE's Avatar
Default RE: 1986 headlight problem
Hey, sounds like the motor crapped out. It might be binding up or the motor is worn out going in one direction. You might want to test amp draw as it operates. If the motor draws more while trying to close it most likely needs help. Good luck
Old Feb 19, 2008 | 01:04 AM
https://www.corvetteforums.com/m_43558/tm.htm
Or this re-compilation...
http://forums.corvetteforum.com/show....php?t=1848666
Both are of my '94, and I think your '86 has some parts that are different. I guess you'll find out when ya' get there...
grabie
Jan 29, 2007 09:03 PM
chase sperry
Jun 14, 2006 02:48 PM
steelman09
May 17, 2006 09:31 AM
grabie
Feb 17, 2006 06:35 PM
Daveloves
Dec 16, 2005 02:32 AM
