1992 Luggage Cover/Shade
Old Nov 12, 2005 | 07:42 PM
JRGonzo's Avatar
Default 1992 Luggage Cover/Shade
How do you remove the luggage cover/shade? I've removed the rear trim like is says in the manual. The manual then says to use the appropate tool to remove the shade. What the heck is the "Appropate tool"?
Old Nov 14, 2005 | 01:11 AM
bobbyj's Avatar
Default RE: 1992 Luggage Cover/Shade
One end of the shade is spring loaded and you will need to apply pressure to depress the spring. There are slots on the end of the shades that you will need to align while applying pressure and pull out one end at a time. The tool suggested is a fork type tool that helps you depress the spring but you can do it by grabbing the shade, apply some pressure to one end and lift the shade forward to remove.
I hope this helpsj!
Lotadoh
Dec 27, 2008 05:34 AM
ken93vette
Sep 23, 2007 03:54 PM
86Project
Jul 22, 2007 12:04 AM
akabyron
Jul 15, 2007 10:44 PM
RobertAz2005
May 25, 2006 04:08 PM
