92 handling
Old Aug 7, 2007 | 01:11 AM
Breeze's Avatar
Default 92 handling
Got a '92 w/45K. Runs great and handles great with the glass top on. But, take off the top and it shimmies and shakes like it's gonna fall apart. Any suggestions on how to tighten it up?
Old Aug 7, 2007 | 07:06 AM
LeesVette's Avatar
Default RE: 92 handling
With the top out the only thing your going to be able to do is buy a brace that will help some. There isn't much to be done in this department except keep the top in.
Old Aug 7, 2007 | 11:46 AM
84corvetteC4's Avatar
has your car ever been in an accident, if so it may not have been reapired correctly, you can but a brace they make for the vert's but its a pain to remove the driveline assembly then[:@]
try thesehope it helps)
http://www.livermoreperformance.com/...e_chassis.html
http://www.bmrfabrication.com/F3-chassis.htm
http://www.thunderracing.com/catalog...es&pcid=60
Old Aug 7, 2007 | 12:03 PM
JoeVetteman's Avatar
Unfortunately,the C4 was never known for being the most rigid car in the world,especially with the top off.There is this brace Mid America sells called the Targa Truss Bar.It gets bolted to the roof just like the factory top.It makes the car look like it has T-tops while at the same time strengthens the car and stops the shimmying and rattles....but it's pricey....about $400.But it looks like it works.I'm thinking of getting one myself.
Old Aug 7, 2007 | 05:45 PM
Here's the reason, and the solution:
http://www.vetteweb.com/tech/0209vet...all/index.html
They had a last-minute design change. T-top ---> targa top.
Convertibles don't shake the same way our targa's do...[:@]
skinnerchief
Jan 15, 2007 04:32 PM
BADDUCK
Dec 22, 2006 01:07 PM
madjak
Sep 13, 2006 11:36 PM
dsnyder5
Jul 4, 2006 02:07 PM
Kirch
May 12, 2006 09:48 AM
