93 starting problem
Old Dec 30, 2008 | 02:19 AM
mdc1855's Avatar
Default 93 starting problem
Hello everyone, I,m new so bear with me. My 93 starter went out so I replaced it. Now it turns over fast,but won,t crank unless you hold throttle wide open or pump gas peddle. When it finally cranks its loaded with fuel and misses untill you blow it out then it runs fine. Before the starter went out it cranked right up without doing anything. Can someone tell me why its doing this. Thank you for any help.
Old Dec 30, 2008 | 07:26 AM
LeesVette's Avatar
Default RE: 93 starting problem
Is it throwing any codes by chance?
Old Dec 30, 2008 | 03:20 PM
mdc1855's Avatar
Leesvette Thank you for your imput, but I found the problem. It was the fuel pressure regulator. When I took the vacuum line off, it was pouring fuel out of the line. I replaced the regulator and it cranksup fine.
Phinallya90
Jun 14, 2007 08:57 PM
GREENSKIN
May 6, 2007 12:35 AM
Bagpipingjake
May 3, 2007 07:25 PM
Phantom
Dec 31, 2005 08:09 PM
NHRalph
Oct 18, 2005 09:55 PM
