93 starting problem
Hello everyone, I,m new so bear with me. My 93 starter went out so I replaced it. Now it turns over fast,but won,t crank unless you hold throttle wide open or pump gas peddle. When it finally cranks its loaded with fuel and misses untill you blow it out then it runs fine. Before the starter went out it cranked right up without doing anything. Can someone tell me why its doing this. Thank you for any help.
Leesvette Thank you for your imput, but I found the problem. It was the fuel pressure regulator. When I took the vacuum line off, it was pouring fuel out of the line. I replaced the regulator and it cranksup fine.
