96 LT-1 Corvette Won't Turn Over/Start
Old Oct 27, 2007 | 02:49 PM
Michael08075's Avatar
Default 96 LT-1 Corvette Won't Turn Over/Start
I just bought a 96 LT-1 corvette a few weeks ago. It's been starting within 2 secs of turning the ignition every time. Today I tried to start it, and the engine just cranks, but does not fire up, just a slight lope after I get off the ignition, then stops after a few seconds.How do I check for error codes. Could I have flooded the engine? Not sure what the problem coulde be.Can anyone help. Thanks... Michael Beckett.
Old Oct 28, 2007 | 07:22 AM
Default RE: 96 LT-1 Corvette Won't Turn Over/Start
Need to purchase a spark checker from your local auto parts to see if you have spark while cranking. Also, need to check fuel pressure with a pressure gauge to see if you lost pressure. Could be a pump, ignition module, coil, and so forth. Do you have tach deflection while cranking? That will tell if your Opti module is working.
Old Nov 10, 2007 | 01:02 PM
I totally over-reacted, and it seems that I may have flooded the engine by pumping it before I cranked it, as I'm used to doing with my ex-86 carburated 305 camaro on a cold start. After about an hour, the corvette fired right up. The camaro has since been sold for the low, low price of $1000, and had alot of life left in her. Thanks for the reply.
Michael.
PinnacleWax
Mar 12, 2014 04:18 PM
ksz90
Sep 28, 2013 04:32 AM
stlvet
Oct 23, 2009 05:07 PM
bollaman
Apr 20, 2009 02:15 PM
