96 rear brakes swap to 85 will it work?
Old 10-20-2007, 09:36 PM
AXE's Avatar
AXE
AXE is offline
Default 96 rear brakes swap to 85 will it work?
I have 2 85's a 90 , and a 92, the 90 and 92 stop great but the 85's dont ,infact it can be scary at times.I just picked up a 96 parts car and was wondering if a swap would work. looking at the 85 the e brake is set up like a small drum brake on the inside of the disc in the hat area, and the 96 just clamps the disc, if i remove all the drum e brake crap from the 85 and change the bracket with the ears for the caliper from 96over to the 85then put the 96 disc and caliper on will it work correctly? or am i overlooking something here ? any one out there done a swap like this ? i am ready to do this tonite but i dont want it to be a waste of time .... any input will be helpful thanks in advance
Old 10-21-2007, 08:06 PM
Default RE: 96 rear brakes swap to 85 will it work?
You need to make sure that the wheels you want to use will fit. I read something about that, when I was looking for a rear end to use for my '40 Olds. I'm looking to fit 15 inch wheels and flabby tires on it though, and the later design won't take 15's. Might not apply here though, because you are probably using larger wheels. Probably should check it though.
Old 10-24-2007, 01:25 PM
AXE's Avatar
AXE
AXE is offline
thanks, decided to sell the 85's and keep the 90 and 92. the swap does in fact work for anyone who wants to know.
hotrod66stang
04-03-2006 02:32 AM
bobashton
10-27-2005 03:43 PM
77vettedude
10-05-2005 11:39 PM
rolliq
10-03-2005 01:30 PM
pt6Dave
06-29-2005 07:44 PM
Quick Reply: 96 rear brakes swap to 85 will it work?
