Air pump wobbles, makes noise. Any thoughts? 1990 C4
Old Oct 26, 2007 | 11:23 PM
cjdietzman's Avatar
Default Air pump wobbles, makes noise. Any thoughts? 1990 C4
Hi,
I just purchased a 1990 C4 with about 66K on it. The smog pump (air pump) wobbles when idling, and it makes noise. Anyone else have this problem? Not sure if the pump is bad (bearings, etc), or if it is a problem with a pulley, etc. Any thoughts or input would be appreciated. THANKS!
Old Oct 26, 2007 | 11:50 PM
infinity999's Avatar
Default RE: Air pump wobbles, makes noise. Any thoughts? 1990 C4
I bought a '90 earlier this year and the air pump was making noise. I just changed it. They are only about $50 at rockauto.com. The one I got works fine..
Old Oct 27, 2007 | 12:08 AM
84corvetteC4's Avatar
your air pump has reached its limit of use it sounds to me,sounds like it time for areplacement to me, make sure to have it replaced before your belt gets thrown off and you get a fat towing bill[:@]
Old Oct 27, 2007 | 10:59 AM
cjdietzman's Avatar
Thanks for the responses fellows. Infinity, question for you: Was your pump also visibly "wobbling" or shainking prior to your replacement, or was it just making noise?
Old Oct 27, 2007 | 11:17 AM
No wobbling or shaking, just bearing noise. I have had the car for about 10 months and have replaced various items that have gone bad or were bad on the car. You will find this common on cars this old. Not sure about your mileage, mine is at about 93k.
Killer_Ride05
Apr 3, 2008 01:22 PM
rjensen
Feb 26, 2008 09:04 AM
pick_a_part
Feb 19, 2008 11:53 AM
TheHIDHookup
Oct 25, 2007 01:55 AM
damon2020
Jul 5, 2006 09:54 PM
