Brake caliper came out
Old Jan 8, 2023 | 01:07 PM
Hisown's Avatar
Question Brake caliper came out
I have had extensive brake work done recently. Yesterday my right front calipers came out or the mounting bracket. My son and I were able to get them back in without removing the bracket. To me that seems like an impossibility unless the new calipers are not the correct ones, or the bracket is damaged. This 88 C4 has only 54K miles, so that doesn't seem likely either. I did have a hard pull to the right during hard brake that has since seem to have virtually gone away. I could buy a recon bracket, if that makes sense. I will contact Mavis Brakes to have them check the pers are the correct ones. Not sure what to do to correct. We ran a wire round them to hold them in place to get the car home. Any Thoughts or recommendations?
Old Jan 8, 2023 | 05:31 PM
It's really dangerous to have brake issues like that. Have you considered calling the guys that did the brake work and get there input?
Old Jan 9, 2023 | 01:38 PM
Hisown's Avatar
Default Talked to brake shop.
The agree that it seems impossible. I ordered a replacement on e-bay and will take it in and find out if calipers were wrong or if old holder was damaged.
Old Jan 9, 2023 | 05:07 PM
While I am not familiar with the C4 caliper mounting method, I've never seen calipers that weren't securely fastened one way or the other.
Have you compared the right front system to the left front system to see if they might have left something out?
Old Jan 17, 2023 | 09:57 AM
Hisown's Avatar
Turns out that the half round notch that holds the caliper retaining pin was more oval than round and the pin came out. Car only has 50K miles, so I'm surprised to see that wear. Now I've head strange sound from the drivers side. Going on a small rest run later.
Old Jan 17, 2023 | 02:39 PM
Mystery solved that's good news. A hole egging out at 50K seems odd. Thanks for sharing..
Old Jan 18, 2023 | 02:10 PM
Odd indeed. I guess a picture would help understand what's going on here.
ms sux
Oct 3, 2008 09:54 AM
gigabyte
Oct 1, 2007 10:36 AM
cone basher
May 30, 2007 08:20 PM
mcgilles
Jan 14, 2007 10:22 PM
Patrick
Jul 2, 2005 10:15 AM
