Can you identify this wire
Old Oct 27, 2019 | 05:09 PM
Streamachine's Avatar
Default Can you identify this wire
This wire I just noticed is not connected? Disconnected the battery recently... car runs fine, but has been running HOT. Not sure if it's associated with the cooling fan not running - which will be my next post. Any suggested as to where this should be connected? Thanks!
Old Oct 28, 2019 | 11:33 AM
Northwoods79's Avatar
If you have a tester check to see if it’s a positive or negative lead. If you’re having cooling fan issues- that may be the problem
Old Oct 28, 2019 | 10:22 PM
Thank you! I'll try that - any idea where / what it should be connected to?
Old Oct 29, 2019 | 02:00 PM
after looking closer there’s 2wires connected to 1 terminal. I don’t know much about the C4 but the factory typically doesn’t run wiring that way, so I would look at after market installation parts. It looks to be a positive connection so try your best to trace the wire back to its source.
Old Nov 1, 2019 | 01:04 PM
I'll try that - much appreciated!
mikenann
Feb 29, 2008 09:57 PM
Clayton
Sep 27, 2007 02:39 PM
jpflhr
Aug 18, 2007 08:30 PM
Bagpipingjake
Aug 10, 2006 01:23 AM
imb1987
Feb 22, 2006 06:51 PM
