Cooling Fan
Old Feb 27, 2008 | 01:34 PM
mikenann's Avatar
Default Cooling Fan
Hi all
It appears that my cooling fan is coming on and not shutting off when the coolant temp comse down. The air is not on. This has caused the battery to drain down once already. What should I look for relay or what?
Old Feb 29, 2008 | 07:47 PM
larry00's Avatar
Default RE: Cooling Fan
Welcome Mikenann you certainly came to the right place for info but for anyone to respond and look intelligent they would have to have a little basic info namely the year of the car.
Just as an opener you can most likely do a search right hereand find the codes for your car and how to access them.
I think I have the link and will look for it .
I'm at work my vette is 450 miles away in bed in the garage.
There are several things that could be causing the problem the most expensive would be the computer but most likely it's a relay or your coolant temp. sensor.
Also it could be a short in a wire or connector.
Do the codes first then look closely at your wires at the fan and look for signs of someone using a probe that broke the plastic insulation on the wires looking for voltage..
Also look for melted insulation in the wires going to the fans.
Some c-4 relays are attached to your radiator cover driver side.
Good hunting and push your AC off switch several times as they go bad too.
Hah I was right , had it in favorites ! If yours is OBD2 pre 96 save the link or most books have it.
http://www.troublecodes.net/GM/
Old Feb 29, 2008 | 09:57 PM
If the fan stays on while key is off, it would have to be the cooling fan relay on the left fender well. Try unplugging it to see if fan goes off.
oldtvman
Sep 21, 2012 07:29 AM
jpflhr
Aug 18, 2007 08:30 PM
khaki1967
May 15, 2007 10:06 PM
sam
Aug 27, 2006 05:46 PM
Bagpipingjake
Aug 21, 2006 11:20 PM
