84 vette cooling fan
Old Aug 15, 2006 | 03:49 PM
sam's Avatar
sam
Default 84 vette cooling fan
hi,i recently purchased my first vette,i was wondering if any one knows if the cooling fan stays running after the engine has been shut off or if the fan stays running until the engine is cool?the temp seems to skyrocket when i shut
the engine off.
ty
sam
Old Aug 15, 2006 | 04:17 PM
TopSpeed's Avatar
Default RE: 84 vette cooling fan
I believe it's supposed to shut off when you turn the car off. Increases in coolant temperature are completely normal when you turn the car off... the coolant is still reacting with the hot motor and cooling it off, but the water pump and all that isn't turning, so you have no coolant flow. Now, if it spikes bigtime, maybe there's a deeper problem there, but just a small increase is totally normal.
Now, with that being said, you should wait for one of the tech's here on the site to respond... I could be wrong on this, but thought I'd just pipe up quickly in case it was useful to you....
Old Aug 16, 2006 | 02:09 AM
raisinbran's Avatar
Top Speed has it right.
Old Aug 27, 2006 | 05:38 PM
oldtvman's Avatar
Ecklers have relays that kick on at a much lower temp. the kits are around $40, well worth the investment.
Old Aug 27, 2006 | 05:46 PM
oldtvman's Avatar
as a foot note it's the temp switch from Ecklers that has a modified temp threshold, it's $40 too,
oldtvman
Sep 21, 2012 07:29 AM
ru10707
Aug 28, 2007 06:46 PM
jpflhr
Aug 18, 2007 08:30 PM
khaki1967
May 15, 2007 10:06 PM
Bagpipingjake
Aug 21, 2006 11:20 PM
