View Poll Results: Why is the C4 so unpopular, even though it is called America's Supercar?
Underperformance/Underpowered/Boring
50.00%
Not Aesthetically Pleasing/Ugly
100.00%
Multiple Build Quality Issues
100.00%
Entered The Sports Car Dinosaur Age/Not considered a legend yet
0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Door Lock Actuator Alternate Part
Old Aug 15, 2024 | 12:39 AM
1994 C4 RestoMod's Avatar
Angry Door Lock Actuator Alternate Part
Hello all, I am looking for a alternate/substitute door lock actuator for my 1994 C4. The OE Part number is 22137716, which is discontinued (of course, what isn't) but looking around, the ACDelco 15841665 seems like it will fit. I am wondering if there is anyway to verify, or if anyone has tried subbing in this part? I also wanted to find out if there is a way to talk to GM and see if they have some sort of recommendation. What say you all??
Old Aug 15, 2024 | 07:02 AM
Welcome to the forums. Have you checked the power to the actuator? Test the actuator with a different power source to make sure it's bad? You can call a Chevy dealership and talk to the parts guy and see if he has a cross reference for that part. There are actuators that are a close fit, you can adapt. I installed a door lock actuator on my 77 (had manual locks only) that came out of a 92 blazer adapted it and works fine, there are ways.
Old Aug 15, 2024 | 08:18 AM
Corvette salvage, or ebay might be a good place to look.
Old Aug 15, 2024 | 08:29 AM
Amazon says they have one for $86
Old Aug 15, 2024 | 10:42 AM
Well first, I’m not having troubles with the one installed. I am Restoring this 1994 from the frame up. Thus, I’d would like to install a new actuator that is new rather than reinstall what came out. Since I am replacing the door, this is the time to replace it rather than have it fail after I reinstalled the whole assembly. So while I have it disassembled and the parts laid out, I’d rather just replace it with a new lock actuator.
Thomas 77. Could you send me the link to the actuator at Amazon? Thanks
Old Aug 15, 2024 | 12:50 PM
I googled the DLA186 standard # and if you go to the amazon site it pops up as a door lock actuator. I'm not sure if that looks like the one you are looking for, pictures are deceiving sometimes. Looks as most manufacturers stopped making that part.
Old Aug 15, 2024 | 06:22 PM
it should look like this. The DLA186 Looks completely different.
Old Aug 15, 2024 | 07:09 PM
Looking on eBay. They have new actuators that are a very close match that discription.
Old Aug 15, 2024 | 08:58 PM
I have seen those. I guess I will need to use the trial and error method as to whether they are interchangeable. I just wanted to verify that an updated part (like an actuator for a 1998 gm) will work. I mean there are NOS parts that look the same but are different part numbers. I’m sure it will work electronically unless there is an issue with VATS. Although, the 1992 and 1993 have Vats and use the c3 actuator. I wonder if I can retrofit? Something worth exploring.
Old Aug 16, 2024 | 06:59 AM
They look the same buy and compare.
Gohot
Apr 23, 2012 05:23 AM
chuck
Feb 15, 2009 07:40 PM
Baudier
Jun 19, 2008 10:27 PM
redvet
Apr 30, 2006 07:50 PM
LeesVette
Apr 7, 2006 10:07 AM
