Head Light Motor Run Time
Old Jan 26, 2008 | 02:13 PM
JJVette's Avatar
Default Head Light Motor Run Time
My headlight motors continue to run after the headlights have rotated into place, either opened or closed. They run for maybe 4 to 5 seconds. Is this normal? The owners manual doesn't say anything about it. I have the GM shop manual and it doesn't say what shuts the motors off either.Thanks for your help.
Old Jan 26, 2008 | 05:13 PM
YANKEECORVETTE's Avatar
Default RE: Head Light Motor Run Time
Does both headlights have the same problem? Most likely stripped gears in the motor assembly.The motors shut themselves off when the current in them reaches a certain level. There is a metal gear upgrade to fix the problem.
Old Jan 26, 2008 | 05:59 PM
JJVette's Avatar
Yes, both motors run the same time. Where can you get the metal gear upgrade if this is what I find? Thanks for the help.
Old Jan 27, 2008 | 11:55 AM
Mid America Motorworks or Ecklers both sell the same repair parts< check both out for your application and price. GOOD LUCK.
Old Jan 28, 2008 | 08:19 PM
PD's Avatar
PD
Not sure what year you have but it sounds like your Delrin bushings have crumbled into obscurity..... I had the exact same symptoms, and sure enough with the help from this forum learned this was probably the problem. I just replaced them on my '96 CE this past weekend. Got them from Mid America for $8.00 per side. Not too hard to do, just takes time and patience, and be careful with your paint.....
Old Jan 29, 2008 | 06:22 PM
JJVette's Avatar
Thanks to all. I'm sure it's the plastic bushings. The gears could be bad but the movement seems very krisp and the doors are tight. Also, found some white powder under 1 motor. Looks like a good winter job.
Thanks again.
Old Feb 22, 2008 | 05:06 PM
JJVette's Avatar
THANKS to all again. I replaced the bushings and everything is fine now. The gears were in good shape. The first one took about an hour, the second about 30 min. Thanks again.
LTC Spivey
Apr 16, 2013 09:51 PM
Trooper
Aug 7, 2010 07:52 PM
t1vette
Apr 12, 2006 09:45 AM
jdavis
Aug 26, 2005 01:15 PM
