Low cooling light
Old Oct 23, 2023 | 06:03 PM
1988Vette's Avatar
Default Low cooling light
1988 C4 Drained cooling system,new anti freeze + distilled water. Now low cooling light Any ideas?keeps coming off and on. All levels correct. Any ideas?
Old Oct 24, 2023 | 12:34 PM
Welcome to the forum. While I don't know how they sense the level, I would try to determine if the sensor itself is working. If it is, then I would make sure that all of the air has been removed from the system.
Old Oct 24, 2023 | 10:34 PM
Welcome, It does seem rather odd the light comes on after a service. Is there a possibility you bumped the sensor or the wiring at the sensor creating a bad connection? Sensor may be cracked or broken or corroded. There is a module in that system also. If you pull the sensor out and test it make sure the probe is clean.
Plumwild
Sep 20, 2021 08:13 AM
KoolKell
Aug 9, 2020 01:47 PM
GrampsC4
Oct 15, 2007 11:56 AM
texvette
Jan 6, 2007 05:46 PM
7771994AZ
Jul 10, 2006 02:50 AM
