Oil Dip Stick tube removal
Old Mar 22, 2007 | 11:49 AM
jph's Avatar
jph
Default Oil Dip Stick tube removal
Greetings, getting into tearing the heads down on my 89,discovered a leak at the rear of the right cylinder head at the block.The dip stick tube needs to be removed, once the header bolt is removed does the tube just pull out? I can't seem to find another bolt or bracket, so do I just apply more force to remove it?
Also planning on using FEL PRO gaskets to seal it back up, good choice?
Old Mar 22, 2007 | 06:43 PM
78buckshot's Avatar
Default RE: Oil Dip Stick tube removal
I don't have experience on the 89 engine but on the older models the dipstick tube is just press fit, twist and pull. FEL-PRO is my 1st choice in gaskets.
Old Mar 22, 2007 | 07:49 PM
Black86vette's Avatar
2nd on the felpro. The cheapie gaskets are garbo.[&:]
Old Mar 23, 2007 | 12:33 AM
The dipstick tube is press fitted into the block with no attaching hardware. They are sometimes a real bear to get out, especially with the block still in the car. I would order another tube from Ecklers or GM and hve it just in case. You can try a pair of vise grips to try and work it out. Good Luck [8D]
Old Mar 23, 2007 | 02:11 AM
jph's Avatar
jph
Thanks guys
KT NOAH
Jun 18, 2008 02:45 AM
May 27, 2007 11:24 AM
topless
May 4, 2007 01:19 AM
CaptainCrunch42
Jan 21, 2007 11:02 PM
alienbeing316
Nov 16, 2005 03:32 PM
