oil pressure guage
Old May 24, 2006 | 06:51 PM
byedan1's Avatar
Default oil pressure guage
well my next problem my oil pressure gauge shows 80+ psi when on the road and 70+ at idle is this ok. when i turn the engine of the oil pressure gauge is showing about 40 psi, is my gauge bad or what?
Old May 25, 2006 | 12:03 AM
byedan1's Avatar
Default RE: oil pressure guage
i am sorry i should have given more info it is a 94 model with a automatic
Old May 28, 2006 | 11:32 PM
corvette king's Avatar
well your pressure sound good,the gage should go back to 0 when the car is off, so it sound like the gage is getting stuck on its way back down,but your oil pressure is great hope this helps
Old May 29, 2006 | 05:29 PM
byedan1's Avatar
changed oil so it sits at about 65 at idle when warm and 75 to 80 cruiseing
Old May 30, 2006 | 12:28 AM
80 lbs is a bit high. Key on, engine off gauge shows around 40 lbs, I would unplug the sending unit and see what happens. If the gauge either goes full scale or returns to zero, I would suspect the sending unit.
Old May 30, 2006 | 11:34 AM
byedan1's Avatar
with the key on engine off it sits at about 10 psi and now that i have changed the oil, warm oil pressure is about 65 psi thanks Daniel
Old May 31, 2006 | 10:21 PM
I HAVE A 92 LT1 WITH A MECHANICAL GAGE I HAVE 70 IBS WHEN DRIVING AND 50 AT IDLE
Old Jun 1, 2006 | 12:30 AM
byedan1's Avatar
i think mine is 65 at idle so i believe that we are running about the same oil pressure
john2517
May 5, 2008 05:28 PM
billennium
Sep 11, 2006 03:47 PM
fj40dana@hotmail.com
Jul 4, 2006 01:23 PM
Patterti
Feb 22, 2006 02:29 AM
Vet Head
Oct 31, 2005 02:17 PM
