Passive keyless entry
Old Mar 12, 2008 | 09:44 PM
Grouch C4's Avatar
Default Passive keyless entry
What is thepassive keyless entry
Old Mar 13, 2008 | 12:22 PM
Ric's Avatar
Ric
Default RE: Passive keyless entry
hi Grouch
the passive key less entry sometimes referred as the PKE is the locking and unlocking of the doors in the 1993 and later corvette with the key fob.
Old May 18, 2008 | 08:40 AM
txcwi's Avatar
Where is best place to obtain a PKE for a 1993corvette? and what does it take to activate it?
txcwi
Old May 18, 2008 | 12:58 PM
Viscount's Avatar
ORIGINAL: txcwi
txcwi
I would try e-bay initially. Dealers & other vendors are asking $125 or so.It shud come with programming instructions, If it doesn't someone here can help.
Old May 18, 2008 | 03:11 PM
smithj4's Avatar
The only ones you will find on ebay are either close to dealership priced, or they're broken. The broken ones will usually bid up to almost new priced so you might as well buy a new one. When I bought mine the reciever for the PKE was disabled, so I could not use the Fob. So I would make sure that's turned on before spending the money. Good luck.
Old May 22, 2008 | 01:44 PM
beauchampgl's Avatar
The instructions for programming the PKE are in the owner's manual. Up to three fobs can be programmed to the same car.
Old May 22, 2008 | 08:01 PM
larry00's Avatar
I purchased mine here. Identical to the Factory one.
http://www.keylessride.com/order/quo...;frid=34DBDECE
instructions came with it.
Little Moe
Feb 19, 2008 12:49 AM
jargusLT4
Dec 3, 2007 06:10 PM
larry00
Jun 7, 2007 09:58 PM
jndnaps
May 13, 2006 12:11 AM
mtsumedi
Dec 14, 2005 01:55 PM
