Quick oil question
Old Feb 27, 2008 | 09:24 AM
95trplblkandtan's Avatar
Default Quick oil question
How many quarts of oil does my 95 lt1 hold, is it 6 or 8
Old Feb 27, 2008 | 09:36 AM
Viscount's Avatar
Default RE: Quick oil question
Use 5 if you also change the filter. Anything over 5 is too much!
Old Feb 27, 2008 | 06:48 PM
JoeVetteman's Avatar
I agree.....5,not much more,my friend.And don't forget,Mobil-1 is the way to go!!!
Old Feb 28, 2008 | 07:17 AM
There's a little fudge above the 'top' mark on the stick.
As long as the crankshaft ain't spinnin' thru it, makin' foam in the pan, you're okay. Just make sure to get the old stuff out. ALL of it...
https://www.corvetteforums.com/m_34280/tm.htm
Old Mar 1, 2008 | 09:31 AM
larry00's Avatar
I've got an oil question too! Changed my oil Mobil 1 last July 3rd and only have 1100 miles on it now.
I can't remember how long syntetic oil can stay in there timewise!
If I hadn't made a 800 mile trip it wouldn't have any miles on it.
Too much work and not enough cruzing !
Old Mar 2, 2008 | 08:42 AM
YANKEECORVETTE's Avatar
Hey larry00, Don't worry about the age of the oil if you use syntetic.I work in the aircraft industry where the equipment is exposed to up and down temperature and humity changes and is tested regulary. As long as you run the engine up to temperature when do run the car and for sum time most moisture and contaminates will burn off. Remember Mobile 1 is used for higher running temps. for longer times w/ less breakdown. I have seen $900k machine run on and off for 10yrs w/ 300gals. of 30w Mobile 1 and test OK a long as water is not poured directly into it. save your money and change it at 6k or 7k miles. good luck
flitemdic
Jun 17, 2007 09:00 AM
dunkarooo
Feb 4, 2007 06:06 PM
rjensen
Jan 28, 2007 12:35 AM
gorichb
Oct 19, 2006 01:24 PM
justadigger
Sep 3, 2005 03:26 AM
