Running rough
Old Oct 4, 2007 | 03:27 PM
Drogo99's Avatar
Default Running rough
1993 Ruby LT1 70K miles. Car is running real rough at highway speed 1500 rpm or so. Almost feels like it is strving for fuel. No codes coming back. I had it in the shop earlier this week and it had a code for EGR coming back and they replaced the valve and at my requirest changed all the plugs. The problem just seems real intermittent when it started doing it this afternoon the SES light did come on but is now offand still no codes....Ideas? Fuel filter? Pump? Clogged injectors?
Thanks!
Old Oct 4, 2007 | 03:47 PM
rshiver's Avatar
Default RE: Running rough
Hi, welcome to CF...Check out this thread, may shed some light on what your problem might be.
https://www.corvetteforums.com/m_43770/tm.htm
Old Oct 4, 2007 | 04:13 PM
ORIGINAL: Drogo99
Thanks!
Welcome drog...
EGR??? On an LT1??? I thought LT1 didn't even have an EGR...
EDIT: my mistake - only LT4 has no egr feed.
Old Oct 4, 2007 | 04:17 PM
Does 15c revs in the driveway do the same thing?
Old Oct 4, 2007 | 08:54 PM
Check fuel pressure. Another might be ignition, such as Optispark, wires.
Old Oct 4, 2007 | 09:08 PM
Drogo99's Avatar
Thanks for all the tips.....that being said this is my first newer toy car, have lots of older chevy's and checking fuel pressure is not a problem, but how fo I do it on this motor....??? Thanks in advance.
Old Oct 5, 2007 | 08:15 AM
LeesVette's Avatar
Connect a fuel pressure gauge by screwing the gauge on to the shrader valve on the fuel rail.
Old Sep 29, 2008 | 03:03 PM
scotth48's Avatar
what was the final outcome on the fix for this as I am having a similiar problem on a '93 Rubby. See "irratic engine"
scotth48
ernie22golf
Jun 19, 2007 06:32 PM
deansreef
Mar 26, 2007 10:36 AM
markcuc
Oct 6, 2006 04:45 PM
dparsons
Oct 5, 2006 09:36 AM
lifelesslived17
Jan 27, 2006 11:34 PM
