shade curtain
Old Jul 19, 2007 | 09:00 PM
86Project's Avatar
Default shade curtain
Still tearing down 86 coupe. Can't seem to figure out the shade curtain. It slides back and forth 1/4-1/2 inch but a cant find a release mechanism. Any thoughts.
Old Jul 19, 2007 | 10:49 PM
Default RE: shade curtain
I just read that today in one of the two links that I sent to you on John Nelson's Vette magazine web links... It takes a special procedure with a screwdriver.
Did you get the shifter **** retainer ring out? Was the pic ok? Can you find the shade removal segment on the link?
ORIGINAL: 86Project
I read those articles prior to beggining the tear down, the issue of the old insulation is really skipped over. The book "101 Projects" states that the transmission insulation should not be removed but no other information elsewhere.
Maybe, maybe not.There's a good picture on the first link tho'. Maybe double check...
Old Jul 20, 2007 | 06:32 AM
beauchampgl's Avatar
It has to be pulled out evenly. Have someone else pull from one side and you from the other. Or else you right in the middle. The thing works something like a window shade. There isn't a release mechanism. Ours wouldn't come out either until we pulled on it kind of hard and then it came out. It had rewound a little bit off center and got jammed up. GOOD LUCK!
Old Jul 20, 2007 | 01:35 PM
ORIGINAL: beauchampgl
According to the article, and the picture, there is a release on the '84. '86too, I betcha'.
Maybe yours (c4 b's) are different tho'.
Old Jul 20, 2007 | 09:55 PM
My '87 just pulls rright out. If there is a latch, it doesn't work, LOL!
Old Jul 21, 2007 | 10:43 PM
86Project's Avatar
Every things on hold. I stripped out the carpet and found two "huge holes" in the fiberglass pan on the drivers and passenger areas. I know what my next project on the PROJECT will be.
Old Jul 22, 2007 | 12:04 AM
ORIGINAL: 86Project
YIKES![sm=yikesomg.gif]
You coulda' been about to rub the H'roids on the assphault. AND pullin' up the family tree by the roots[sm=smiley26.gif]
ken93vette
Sep 23, 2007 03:54 PM
JRGonzo
Nov 14, 2005 01:11 AM
