Strange Sound from Vette
Old Jul 18, 2007 | 09:45 PM
dans87vette's Avatar
Default Strange Sound from Vette
Okay, please don't jump all over my post for lack of information. I'm just trying to get some clues on a very strange noise from the engine area. This noise only happens "now and then", but is really loud. The only way I can describe it is like a Fuel Pump x10 or and electric motor if you stalled it. Almost a lound Humming sound. I know this isn't much, but what could make sounds like that under the hood and then go away after about 30 seconds (EGR valve?, it doesn't seem like it would be a fan because it's not while the car is really warm). I haven't had the chance to get out and pop the hood while it happens, it always seems to be somewhere I can't pull over.
Old Jul 18, 2007 | 11:47 PM
khaki1967's Avatar
Default RE: Strange Sound from Vette
Airpump below front left headlight?
Old Jul 19, 2007 | 05:09 AM
Bigjons86vet's Avatar
does it do it more as you corner? and when you let off the throttle? if so it could very well be your harmonic balancer, the sound your describing is exactly what mine sounded like took forever to find but thats what it was
Old Jul 19, 2007 | 11:22 AM
86 Ironhead's Avatar
ORIGINAL: khaki1967
You might be on to something
Old Jul 19, 2007 | 10:45 PM
Are we talking about the smog pump? If so, what controls when it comes on and off? I'm going to try to get into this more this weekend. Anything else under the hood that can make this type of noise? Thanks for suggestions.
Old Jul 19, 2007 | 11:10 PM
ORIGINAL: dans87vette
Now and when? Under acceleration? De-celeration? Get the stick in neutral - still does it? While braking? Sound increase as speed increases?
Old Jul 21, 2007 | 09:59 PM
Okay, finally got the sound to come on while I could stop and look. Though it still didn't help me much. I popped the hood and still couldn't make out exactly where is was coming from, but it's really loud.It "seemed" to becoming from mid engine, like the manifold area......again, I could make it out for sure.The sound only happens, maybe once a ride or maybe less. It doesnt' seem to matter if the car is high or low idle, moving or in the driveway when it happens. As soon as I rev the gas, it stops and goes away. I know I'm not givingmuch info here, but it's the best I have for now.
Old Jul 22, 2007 | 12:10 AM
Get the belt off of the belt tensioner. Feel the tensioner pulley wheel for lateral movement (not in line with the belt, but like at 9:00 and 3:00, and see if you can go back and forth with it).
Is the sound like a combo rattle/vibration?
Old Jul 22, 2007 | 09:15 AM
HMMMMM........you might be onto something, I was just watching the idler pully the other day and wondered if it's supposed to look as worn (sloppy) as it is. I will check it out today and post back. Thanks
cassy
Feb 21, 2007 12:29 PM
Lucinda
Jan 27, 2007 02:05 PM
ziebob
Jul 10, 2006 09:53 PM
pj1010
May 13, 2006 04:52 AM
Daveloves
Oct 14, 2005 10:58 PM
