squeaky dash
Old Jul 4, 2006 | 09:58 AM
joeinindy's Avatar
Default squeaky dash
Anyone know how hard it would be to fix the squeaks in my 88's dash. The car only has 30,000 miles and is near oerfect but the noise in my dash is driving me nuts.
Old Jul 4, 2006 | 10:46 AM
Default RE: squeaky dash
Can you tell where in the dash it is coming from? The dash pad area? Middle of the console? Instrument cluster? The pad removes fairly easy, couple of screws in the top, four or five underneath. Might have to put some light lube where the dash rubs or the screws may be loose on the the IP.
Old Jul 7, 2006 | 09:10 AM
joeinindy's Avatar
Best I can tell it's coming from drivers side, sounds to be lower part of dash.
Old Jul 7, 2006 | 09:53 AM
If it is lower, then the lower cover might have to be removed and that is more of a chore. There are some studs on the back side of the cover that you will have to gain access to to remove the nuts behind the instrument panel. [:'(] It is not an easy task, but you might have to remove the panel to see if any of the dash mounting bolts are loose.
C4Explosives
Mar 2, 2007 09:21 AM
z06BoZ
Oct 30, 2006 07:52 PM
vavvoom
Sep 9, 2005 01:06 AM
RussellC5
Sep 7, 2005 06:55 AM
jeepin45
Aug 11, 2005 12:57 PM
