Starting problem
I have a 94 LT1, most times when i try to start it, starts right up; recently had the engine crank over for a long time w/no firing...seemed like it was turning over with no plugs in it, (spun rather fast with no compression). It will do this for 5-6 times, then starts like I never had a problem. 10 minutes later, same problem. Help!
Dave,thanks so much for posting the solution to your problem! I couldn't help with the solution 'cause I'm pretty much a newbie around these cars. But,thanks to you,I have one more piece of information!
Thanks again!
Ron
Thanks again!
Ron
