TWO C4 QUESTIONS, NEED HELP
Old Nov 14, 2006 | 11:52 AM
mercedes84black's Avatar
Default TWO C4 QUESTIONS, NEED HELP
1. MY TEMP READOUT STOPPED WORKING, ONLY SAYS LO. I REPLACED THE 2 WIRE TEMP SENSOR ABOVE WATER PUMP AREA AND NO CHANGE, NEED ANSWERS. 2. IS THERE A WAY TO ADJUST THE REVERSE LINKAGE ON MY 1985 4+3 MANNY TRANNY, DOESN'T SEEM TO WANT TO MOVE IN REVERSE VERY WELL BUT ALL OTHER GEARS WORK FINE, HELP PLEASE.
Old Nov 14, 2006 | 12:27 PM
rwolak's Avatar
Default RE: TWO C4 QUESTIONS, NEED HELP
1. the sensor that drives the temp. readout is located on the rear, passenger side between plugs 6 & 8. Should be a one-wire connection.
Old Nov 14, 2006 | 01:09 PM
REPLACED THAT ONE LAST WEEK BUT THE BOOK CALLED THAT A "COOLING FAN SWITCH" TO TRIGGER THE FAN ON AT A CERTAIN TEMP
Old Nov 15, 2006 | 12:05 AM
Temp sending unit is supposed to be driver's side between #1 and #3 spark plugs, single wire. The one above the water pump in the intake is the coolant temp sensor for the ECM. Way to test the gauge is ground the wire going to the sensor with key on. Gauge should go full hot when you do that[8D]
Suppoko
Feb 12, 2014 10:58 PM
94yj
Oct 11, 2007 10:42 PM
Str8upChevy
Nov 28, 2006 01:09 PM
maloneys84vette
Feb 14, 2006 12:44 AM
bmbndb
Oct 8, 2005 02:37 AM
