1995 6spd Corvette
New clutch installed about 800mi or 4 months ago
I pulled into my driveway after a pretty calm cruise and heard some noise that I wasnt familiar with, like other than the loud noise from the clutch/trans that you get used to in a C4. I looked underneath and there is a 4" diameter hole in the bottom of the clutch housing. Its perfectly round, and looks like someone would have used a hole saw to get it so precise, but I can confirm that nobody did that. WTF did I do here?
I'd start checking with the many aftermarket Corvette parts suppliers. If they can't supply one, then check with Contemporary Corvettes. It's a Corvette salvage yard in Pennsylvania and they might be able to help you out.
I not sure if that hole is stock, looks a little oversized to me. It has been awhile since I have seen the bottom of a c-4. You might need to build a cover if one can't be found.
Made one tonight with some steel mesh and high temp aluminum tape.
