04c5 Telescopic streeing
When operating my telescopic button all I hear is the motor running and nothing else happens forward or backwards its like the drive gear isn't connecting just wondering if body has experienced this if so how did you fix it thanks for any info
Welcome to the forum .
I don't know if they use some type of rack and pinion gear setup or a screw drive but it sounds like either way the motor is not connected. Either a set screw or a broken gear could be the problem. If it's a plastic gear then it's quite likely that several teeth have gone South on it.
DeepCrush
Nov 13, 2006 01:04 AM
