04c5 Telescopic streeing
Old Dec 8, 2020 | 02:30 PM
04c5's Avatar
Default 04c5 Telescopic streeing
When operating my telescopic button all I hear is the motor running and nothing else happens forward or backwards its like the drive gear isn't connecting just wondering if body has experienced this if so how did you fix it thanks for any info
Old Dec 9, 2020 | 08:30 PM
Welcome to the forum .
I don't know if they use some type of rack and pinion gear setup or a screw drive but it sounds like either way the motor is not connected. Either a set screw or a broken gear could be the problem. If it's a plastic gear then it's quite likely that several teeth have gone South on it.
Old Dec 10, 2020 | 09:14 AM
04c5's Avatar
Thanks 73 shark do you know if the steering column comes apart to check I can't find any info or diagrams on this
Old Dec 10, 2020 | 12:01 PM
My 73 steering column can be accessed by pulling the steering wheel and working your way down into the Tilt/Telescopic mechanism. Not sure about how the C5 is put together though.
Old Dec 10, 2020 | 02:13 PM
04c5's Avatar
Thanks again 73 shark saw some pictures of parts on ebay slowly starting to get this figured out
Sep 29, 2007 06:40 AM
95trplblkandtan
Apr 16, 2007 08:18 PM
DeepCrush
Nov 13, 2006 01:04 AM
vettemanrob
May 30, 2006 10:24 PM
jdavis
Sep 3, 2005 11:29 PM
