ac problem
Old Jul 29, 2019 | 06:47 AM
99C5's Avatar
Default ac problem
having an issue with the AC on my 99 vette bought this 1 owner that was only driven less than a 1000 miles a year for the past 9 years takes a while for ac to cool
then I hear liquid sloshing behind the dash then water under passenger side, any suggestions?
thanks
Old Sep 19, 2019 | 02:18 PM
The weak cooling might be caused by a low charge of R134a in your system.
The water sloshing around is probably condensate in the evaporator housing and you will need to clean the drain valve on the bottom of it. I believe that's located on the bottom side of the evaporator housing in the engine compartment. Usually looks like a piece of rubber tubing that's been smashed together.
Rixvette
Jun 14, 2017 10:06 PM
kdlokey
Aug 7, 2015 10:24 PM
1993corvette
Jul 25, 2007 10:38 PM
97C5 Owner
May 16, 2007 09:44 PM
aspmaster
Mar 27, 2007 10:35 AM
