Aggravating front end squeaks
Old Dec 28, 2007 | 03:34 AM
myc5's Avatar
Default Aggravating front end squeaks
Seems like this has been getting worse with the colder weather now, but it is becoming very irratating.
Pretty much a constant squeak under normal driving conditions coming from the front. I have changed out the bushings for the sway bar but that didn't help. There are no Zerk fittings to grease under there, so my question is could it be the bushings or something else?
There is only 41,000 miles on my 98 and all the bushings look good as far as wear goes.
Could they have just dried out to the point where they are making this noise? Any way to apply some lubricant to them to soften them up?
Hope someone else here has had the same issues and can help...
Thanks
Old Dec 28, 2007 | 12:41 PM
Dave01's Avatar
Default RE: Aggravating front end squeaks
This happened to me when I had my 68, immediately after installing urethane bushings for the sway bars. I applied grease (I think it was a Teflon-based grease, like the stuff that Slick 50 makes) to the bar where the bushings were located and the problem went away. In any case, make sure the grease you use is compatible with the rubber bushings.
Dave
Old Dec 28, 2007 | 03:04 PM
myc5's Avatar
Thank you
I will try that
Old Dec 29, 2007 | 12:14 AM
You might could try some silicone spray as well. I don't know if it will affect the bushings or not but you could test it and see. Good luck with it. Cheers
Old Dec 29, 2007 | 06:11 AM
Also spray some lithium grease on control arm bushings (upper and lower) and grease your tie rod ends.
vettemanrob
Jun 4, 2011 10:09 AM
BigJay
Jun 13, 2007 02:04 PM
lrfowler1
Oct 21, 2006 11:54 AM
gorichb
Aug 21, 2006 07:11 PM
jdavids
Jul 16, 2006 10:39 PM
