98 belt squeaks?
Old Jul 12, 2006 | 06:40 PM
jdavids's Avatar
Default 98 belt squeaks?
My 98 continues to have a belt squeak? Both belt tensioners have been replaced along with the belt? Even the dealer is perplexed? Even more odd...the squeak is only when cold...after about a minimum of 10-15 miles, the squeak goes away. Any ideas?
Old Jul 13, 2006 | 09:35 AM
Default RE: 98 belt squeaks?
Clean your crank pulley with a wire brush and brake clean. Also clean any other grooved pulley, after cleaning try a good quality Gates or GM belt. Sometimes you get a build up on the pulleys and the squeak you here is the belt slipping. [8D]
Old Jul 16, 2006 | 10:39 PM
tankerpilot01's Avatar
Not sure if it would work for you.....but my belt was sqeaking on my 97 while I was on the track....and one of the guys that has been around vettes for a long time (nicknamed the "professor") went to his trailer, got a bar of soap out of his shaving kit and with the engine running (obviously) took the bar of soap and held it up against the under side of the belt and after a couple seconds, the squeak went away.....same concept, I would guess as mech259 is getting at.....cleaning.
vettemanrob
Jun 4, 2011 10:09 AM
myc5
Dec 29, 2007 06:11 AM
BigJay
Jun 13, 2007 02:04 PM
gorichb
Aug 21, 2006 07:11 PM
dph
Apr 11, 2006 10:21 PM
