Air conditioning not coming out drivers side
Old Apr 4, 2007 | 02:24 PM
98VetteGirl's Avatar
Default Air conditioning not coming out drivers side
I have a problem with my air conditioning on my 1998 coupe. The passenger side gets nice and cold, but the drivers sideonly blows warm air.[/align]I have the dual climate control system, but even with the driver's side
temperature control set to the maximum cooling position, I only get warm air on the drivers side. Any ideas what could be wrong? Please help!!
[/align]
Old Apr 4, 2007 | 02:29 PM
jerrysullivan's Avatar
Default RE: Air conditioning not coming out drivers side
Have you tried setting the climate control to 60deg and bumping the fan control up, manually?.......... good luck........ 8-)
Old Apr 4, 2007 | 02:45 PM
I've tried that - I think it has something to do with the flappers in the air system not allowing the air to exit the drivers side.
Does anyone know if the flappers are easily reached?
Old Apr 4, 2007 | 02:53 PM
With the fan speed at manual full speed, if you get heavy air flow then my suggestion would be to borrow a "service manual" to investigate the air flow doors. I have an '03 with all three volumes I couldn't get along without.
Good luck....... 8-)
Old Apr 7, 2007 | 10:38 AM
More than likely, your driver side blend door actuator is bad. It is stuck in the open posistion on the heater core blend door and not shutting off the core to keep the heated air out.
Old Apr 10, 2007 | 04:39 PM
Thank you very much! That is helpful! I'm taking it to my mechanic on Friday, so at least I have some idea of what may be going on.
riley6riley
Jun 24, 2008 09:37 AM
PAY2PLAY
May 10, 2006 02:07 AM
jd2000
Dec 11, 2005 04:15 AM
Blemons
Oct 17, 2005 09:50 PM
raymond1ford
Aug 18, 2005 03:11 PM
