Auto Transmission Shifting Wrong
Old Jan 23, 2008 | 05:11 PM
C5Y2K's Avatar
Default Auto Transmission Shifting Wrong
Hey everybody, new to the corvette world. I picked up a 2000 C5 and love it, the only thing i regret is the auto transmission. The shifts were very firm and the car ran consistent 13.6's at the strip. Driving normally, there are no problems, but lately, at WOT it wont up shift on time. When it does upshift, it shifts very firm. At around 50mph when floored, it revs free and then several seconds later it pops firmly into gear.I dont think it is a mechanical problem. The local aamco swapped out the throttle position sensor, for $200, claiming the $37 TPS at autozone was a 3 pin connector and wouldn't work. This helped initially, but now it is as bad as ever. It doesn't feel like the transmission is slipping at all. Whenit does shift, it shifts great.What could cause the transmission to not go into gear, and then when it does, not shift in time?
Old Jan 24, 2008 | 09:06 AM
bados's Avatar
Default RE: Auto Transmission Shifting Wrong
I would take it back to AAMCO and bitch! Take the mechanic for a ride and show him the problem. Obviously the car was not road tested uponcompletion of the job.
Old Jan 24, 2008 | 04:50 PM
C5Y2K's Avatar
I took it back in today and took their mechanic out for a ride. He agrees that it doesn't feel like a mechanical problem, but wasn't pulling any codes either. I noticed that as it climbs higher in rpm it will shift as soon as you let off the gas, but if you don't let off the gasit won't shift into second until 4000 rpm. What controls the transmission electronically?
ZR1clone
Jan 1, 2008 07:17 PM
buddym3
Aug 26, 2007 08:16 PM
buddym3
Aug 12, 2007 03:39 PM
stevesrubyred93
Feb 28, 2007 10:04 PM
vette86
Sep 4, 2005 01:47 PM
