Blinking gauges and dic
Old May 4, 2009 | 09:50 AM
vettemanrob's Avatar
Unhappy Blinking gauges and dic
Hi all well now my 02 is acting wierd, the gauges and dic are turning off and on quickly during the turn of the key into the ignition and the car wont start. It does this for different amounts of time, soemtimes short and sometimes long. What I found that works to get it running is to turn the key back to the accesory position for a few seconds then back to start everything is usually okay. I am thinking that this is a loose or corroded ground connection somewhere since I have checked every fuse, both in the passenger floorboard and under the hood. Has anyone had any similar problems and if so what was your outcome?
Any help would be greatly appreciated.
Old May 4, 2009 | 11:15 AM
Red face
I think I did it! A while back I installed a jet performance chip inbetween the computer and computer harness. There is a bolt holding the harness onto the computer, right in the middle. The bolt was loose so I tightened it and tried to start the car several times and so far so good, no more blinking lights.
Old May 4, 2009 | 10:13 PM
Dave01's Avatar
Thumbs up
Good deductive work! I would've guessed that the infamous door wire bundle exposed wire-in-accordian cover issue was to blame.
rick forman
May 14, 2011 08:33 PM
hawaii06c6
Dec 19, 2007 10:44 PM
vette95
Apr 3, 2007 01:08 PM
POLO GREEN 90
Nov 26, 2006 10:37 AM
rjensen
Sep 23, 2006 05:46 AM
