Coolant temperature
Old Aug 24, 2007 | 01:28 PM
shadetree's Avatar
Default Coolant temperature
I have always had normal highway temperature of 195 degrees. Just changed rotors and and pads and now temp is 205 to 215. Brake change the cause or just coincidence?
Shadetree
Old Aug 24, 2007 | 06:56 PM
Default RE: Coolant temperature
Coincidence.
No heat build-up from new brakes 'break-in', or even harder [brake] use,will prevent radiator cooling, that has been...
If you shorted the ABS circuitry somehow, then it's remotely possible, but unlikely (you'd probably have a light on in the dash).
Old Aug 24, 2007 | 11:02 PM
Architect's Avatar
could it just be the august heat kicking in? ive noticed my '01 gets up to 220 lately in traffic if im stuck at a light for vey long....could it just be the "summer" heat?
Old Aug 25, 2007 | 01:10 AM
chargedvette02's Avatar
Could be your thermostat sticking or just it's really hot or your coolant is kind of low.
Old Aug 26, 2007 | 05:57 PM
Dave01's Avatar
Also, check to make sure nothing (like a plastic bag) has flown up against the radiator.
Other wise, it could very well be the upturn in ambient air temperature.
Old Aug 27, 2007 | 08:57 AM
KenHorse's Avatar
How about the most obvious?
Perhaps your brakes are dragging?
Old Aug 27, 2007 | 12:32 PM
ORIGINAL: KenHorse
Excellent thought there, horse!
It sure ain't an obvious thing tho'... UNLESS, he's noticin' what seems to be a LOSS OF POWER???
lilredc4
Feb 14, 2008 09:18 AM
RudeDog
Jun 6, 2007 10:01 PM
TopSpeed
Jul 24, 2006 03:10 PM
hookemhorns
May 8, 2006 03:57 AM
81Beast
Nov 21, 2005 02:29 PM
